Unfortunately up for sale
http://www.pistonheads.com/classifieds/used-cars/renault/renaultsport-megane/renault-megane-x84-p2-renaultsport-f1team-r26---------2007/6254308
They make great track cars. Also quite easy to make a standard r26 into an r26.r spec (or better) car with after market parts making it an incredible track car.
How do you rate them? . I thought they would make a half decent track car as they can be mapped pretty easy for extra power, decent size brakes as standard and Renault RS handling is usually quite good.
Whats the difference between the two I can't seem to find an R26r to compare
As above, it was stripped out, bucket seats, roll cage, harnesses and r888 from the factory. Iirc it had plastic windows as well. Also had different (softer) suspension to allow for the difference in weight.
plastic rear and rear side windows
carbon fibre bonnet
rear cage + no back seat (although still seatbelts in back)
front harnesses in a bag (with normal belts fitted)
Recaro front seats
no radio (although wiring fitted)
titanium back box
red or black wheels
r888's
GKN diff as fitted to all R26
[Edited on 27/9/16 by prawnabie]
Great cars! Good luck with the sale.
I used to have an r26 which was the Forge development car so had lots of decent little mods. Was running around 270bhp. Amazing handling with the
LSD.
Would recommend!
Deposit taken today. A bit sad to see it go, would definitely have another in the future.
