wanted: Cat converter
blakep82 - 13/11/08 at 09:01 PM
anyone got one which mesteriously fell off their car after SVA?
R1minimagic - 13/11/08 at 10:32 PM
I've got one off a mini cooper..
blakep82 - 13/11/08 at 10:34 PM
mmm how much you looking for?
and will it do for a 2 litre vauxhall?
[Edited on 13/11/08 by blakep82]
R1minimagic - 13/11/08 at 10:36 PM
£25. I can check inlet/outlet sizes if you like?
blakep82 - 13/11/08 at 10:41 PM
£25 sounds good please check the inlet and outlet though, I've also just bought a 1998 R1 can off ebay, so looking for similar pipe size to that i guess. can't remember what size pipes minis had
R1minimagic - 13/11/08 at 10:42 PM
I think they are quite oversized on the inlet/outlet as they are probably off a larger engine. I have an S1 elise and the cat looks identical. Will sort tommorow!
blakep82 - 13/11/08 at 10:45 PM
nice one will measure the original pipes off the vauxhall exhaust in a bit.
just thinking though, don't bikes have to have cats?
R1minimagic - 13/11/08 at 10:48 PM
Newer bikes do yes but they are very small so probably not as efficient for emissions reduction.
And btw - probably extremely expensive!!!
[Edited on 13/11/08 by R1minimagic]
blakep82 - 13/11/08 at 10:58 PM
ah, just wondered
just checked, and its a 2" pipe on the original exhaust, so i'll maybe look at making it a little bigger diameter, but 2" (to 2.5"?) is good i think
R1minimagic - 16/11/08 at 06:46 PM
Just checked and it is 2.25" tapering down to 1 7/8".
blakep82 - 16/11/08 at 07:03 PM
that'll do! 2.25" should be good enough for a 2.0 shouldn't it?
R1minimagic - 16/11/08 at 07:05 PM
Yes unless it has 400hp!
blakep82 - 16/11/08 at 07:10 PM
ooooh, 399hp, so we're just inside it
i wish... will be about 150 maybe
