Hi all,
I am still looking for a 4 speed gearbox with 23 splines input/output I beleive it's the "rocket Box" can anyone help!!. needs to be 23
splines for the stronger box and not the 5 speed.
Regards Steve Evans.
be
quick!
the rocket box's proper name is the type E
the 5 speed type 9 has the same 23 spline shaft (just coz you said it needs to be 23 splines for the stronger box)
they're the same physical size.
i think the rocket is a little stronger though
how much power are you wanting to put through it?
[Edited on 10/6/09 by blakep82]
Blake, if you look at your link the questions at the bottom someone asks how many splines on the input shaft and he says 20.
oooooh, right... ignore me!
The type 9 is a 23x1" input shaft, identical to the type e box.
Unless for some reason you specifically need the 4 speed i would just stick a type 9 in.
^ yep, 5th would be nicer on motorways anyway
david, wasn't the type e a bit stronger though? or was the 5th gear the only difference?
i have a type 2 if anyone is interested? I know this man isn't but someone may be?
I have a spare 4 speed. It's like a 4 speed type 9. I'll count the splines tonight.
My 4 spped seems to have 22 input splines and 25 output. Any use?
