hi i need a small amount of the above about
130x130 mm? cheers ben
use a cereal box used many over the years none ever failed, alternatively can you just use silicone ??
Or hylamar blue?
All Bran gives the best seal!
Seriously cereal or other, thicker cardboard boxes, greased make good gaskets
I used a pizza box for a while .... obviously the brand makes a large difference. I'll give you a clue, mine was a green box.
I bought
this on eBay last month, quick
delivery and quality gasket material.
I've used most of it, otherwise I'd have sent you some, but I can vouch for the seller
My local motor factors has gasket paper.
geat ideas! thanks for all the help i wil try it today ! ben
