M10 12.9 HT bolts
speedyxjs - 27/1/10 at 08:48 AM
Does anyone know where i might find the above? The only ones i can find on eBay are allen heads.
mad4x4 - 27/1/10 at 08:49 AM
namrick ?
speedyxjs - 27/1/10 at 09:32 AM
I can only find 8.8 on their site. do they do 12.9?
turbodisplay - 27/1/10 at 09:39 AM
Doubt you will get 12.9 with anything other than torx or hex head, 10.9 on the other hand will be possible.
Darren
mcerd1 - 27/1/10 at 10:08 AM
is this for your propshaft ?
the flange on the diff is a fine thread (M10x1.0) which is even harder to find....
cap heads (allen key) should be ok - at least I hope so, thats what came with my dax prop
[Edited on 27/1/10 by mcerd1]
matt_gsxr - 27/1/10 at 10:32 AM
Burton power do M10x1x18
These are marketed as propshaft bolts and interestingly are 10.9 (as can be seen from their picture).
I can't get the link to the item to work. It is www.burtonpower.com search on "propshaft bolt (M10x1x18)"
Matt
[Edited on 27/1/10 by matt_gsxr]
mcerd1 - 27/1/10 at 10:45 AM
they look the same as the std. sierra ones
(item: 6118344) linky
speedyxjs - 27/1/10 at 12:33 PM
Yeah but its a Jag diff.
bodger - 27/1/10 at 01:34 PM
I've just been through this but for a Sierra. I couldn't find anything but cap head in 12.9. There is hex head 10.9x1 fine thread on ebay from the stainlessbolts shop. Namrick do cap head bolts & nuts in 12.9 but standard course thread. Have you tried a Jag service centre?
mcerd1 - 27/1/10 at 02:07 PM
for some reson I thought you had a sierra diff (with a jag engine & box of course)
if you totaly stuck, drop me a PM - I might be able to get them but it won't be cheap....
