still not found any
who's got some? surely someone has some tucked away for me?
I had to buy a whole airbox for mine
the trumpets are bolted onto the backplate bit, which is held onto the carbs by the rubbers (rather than bolted to the carbs direct)
there are a few on ebay at the moment, but from the pics they've either had the bit you want removed - or you cant tell if its got it or not
here's some pics of what your looking for if it helps you any:
without the backplate there is nothing actually holding this in place....
[Edited on 30/4/10 by mcerd1]
I'm sure i've got some, i bought the wrong ones for my carbs.
I,ll go and look in the shed now for you.
found them but they're not quite the same.
how do i post a pic?
cheers
upload it to your archive linky
then copy the bit of text bellow it (it'll look like: [img]your_pic.....[/img] (don't capy the link to the page! )
and paste that text into your next post
Cheers, bugger my camera's at work!!!!
I am 99% certain that I have a set, will look in the morning
Yep! thought so do you want the backplate as well?
Sorry for the late replies, yes please! Trumpets, back plate and fitting rubbers if you have them would be awesome
Just trumpets,backplate and mounting bolts I'm afraid.U2U me with your address and I'll send on to you Tuesday.
u2u2u!
U2U2U received
