hi im after a prop end for a type 9 gearbox
or a complete sierra prop anything will do as it will be cut up to my lenth i have the diff end already
cheers doddy
What you need is a Capri or Transit prop so you can get rid of the rubber donut but at the front, the diff ends are all the same
got one sat in my garage you can have for free but im sure there is someone closer
i got a whole prop what size do u need?
hi i just need the end as im having somone make the rest so as long and the whole gearbox end is ok
chris where are you how much do you want for it
afj would you send it in the post im happy to send you money to cover postage and a drink for you
cheers doddy
Really i want as much as possible.what are you willing to pay?
I live in wrexham,i would post.
Chris
I have a prop from a 2WD Sierra Cosworth and I think it's the same input shaft. You're welcome to all of it or bits of it if you want. I was
only going to take it to the tip anyway.
Alex
I've got a whole prop in the garage that is going to the tip, if someone doesn't pick it up.
I don't think I could post it, although it would be funny to wrap it up in brown paper and post it to the reptile section of the local zoo
I've got a shortened prop with type 9 one end and Sierra flange the other.
Don't know how long, but it was used in my Viento when I had a type 9 in there. Could measure it if you're serious.
£20 collected from SL9.
Chris
