I'm after a rear sub frame from an mx5 if anyone's got one lying around - I figured with the number of MX5's being used as donor's
there's a good chance there might be one going spare.
Doesn't need to be in great condition, but does need to be straight. I'm planning the rear suspension for my BEC midget and want to see how
the subframe fits under the rear, then I'll make a tubular version for the end result.
Hi
I've got one but it's still on my car at the moment - I'm about ready to lift off the body after a bit more work so two-three weeks
perhaps (I'm a slow worker).
Can you wait that long ?
cheers
Paul
3 weeks is absolutely fine - you're a much quicker worker than I am
Ok I'll PM you when I've got the body lifted off and stripped the subframe down.
