Driveshaft CV boot wanted
Kriss - 15/11/10 at 01:41 PM
Found a small split on my drive shaft CV boot (diff output end) when swappings diffs yesterday.
Its a sierra 4x4 rear setup (bog standard 3.62 LSD) I have taped it up tight as a short term meassure but ideally want to replace in the next 100 or so miles if not sooner.
mookaloid - 15/11/10 at 02:34 PM
seems to be plenty on ebay
Kriss - 15/11/10 at 03:33 PM
its the diff end. how do I got abotu fitting without taking the lobro/CV joint apart?
omega0684 - 15/11/10 at 05:40 PM
you can't,
1) unbolt CV from the diff,
2) take out the retaining circlip on the end of the driveshaft,
3) take off bearing of CV joint & old boot, Clean & slide on new boot.
4) replace cv joint and retaining clip,
5) bolt back on to diff.
simples!
HTH's
Alex
