Front end only needed if you have it.
cheers.
dave j
do you just need the splined shaft? I have this going spare, tho if I have a dig around I,m sure I can find the donut rubber part too ( I,m pretty
sure I kept it ), its a prop from a Type 9 box fitment.
let me know if any of the above would help.
cheers
andy
[Edited on 19/4/11 by handyandy]
If you are mating to a type 9 the Transit prop works better as it doesn't have have the big rubber donut.
just the splined shaft is perfect to be honest as im getting it modified to work with my BEC. i have the donut thing from the last prop but i nackered
it not lining it up properly while fitting them together.
cheers andy...
u2u sent
Originally posted by handyandy
do you just need the splined shaft? I have this going spare, tho if I have a dig around I,m sure I can find the donut rubber part too ( I,m pretty sure I kept it ), its a prop from a Type 9 box fitment.
cheers
andy
U2U replied to
You are welcome to the splined shaft, just cover the postage cost or I can take it to Stoneleigh, whichever you prefer( how soon you need it ect)
cheers
andy
