Hi All,
As above, I'm in quite desperate need of a motorbike exhaust. Preferably as a slip on and I don't care for the condition (to a degree) if
it's (free) cheap enough!!!
Thanks in advance...
This is why I'm asking, and I doubt that anyone will have an old Suzuki Bandit 600 Exhaust with it's built in link pipe, but if I can get a
normal exhaust or an aftermarket exhaust then a friendly welder-type-man will probably help with a link pipe... May even try and make an underseat
exhaust whilst I'm at it!!!
Couldn't you just cut the rusty section off and weld on a small length of pipe? If you aren't too worried about appearances then you can
even MIG stainless steel with normal wire.
You can probably get a standard Bandit exhaust in good condition quite cheaply as well, they don't sell for much e.g. susuki
exhaust | eBay
That's the secondary plan Mike, but it must be a relative weak point as they are all over £30 odd quid on ebay (the one you posted won't fit
my R reg [I don't think] unless someone can tell me different?)
Anyone?
I would have thought that there were loads of cheap aftermarket exhaustss kicking round LCBer garages! Annoying thing is, I chucked one away a few
months ago, as I was fed up tripping over it!
I got rid of one a while ago too mate
You could have had it for free as it was only takin up space
nevermind, hopefully someone will sort you out
I know a man who has a carbon fibre YZ 600 Thundercat exhaust in boot of his car, if you can get me prices for those Kevlar Vents we mioght be abke to do a trade.
I have a suzuki 900 exhaust i dont need can have for £15
Thanks Sam, will def bear it in mind if nothing closer turns up!
Cheers!
U2U sent re prices Callan
