im after a external tank fuel pump for my zx6r bike carbs anyone know the best/cheapest place to buy one? not being a biker im unsure where to
start(going on a 2.0l zetec)
lewis
forgot to mention i have a weber fuel pump and pressure regulator fitted atm from my webers i removed,i take it these cannot be used for the bike carb setup???
You should be fine with the pump/regulator you have. I run the same set up with a filter king and facet pump. Worth a try to see how it goes.
For what its worth, I run exactly the same as macc man above. This topic has been talked about on a few occasions. Try a search on here.
Thanks guys I did try the search first but just got conflicting answers,I will try with what I have fitted to start with and go from there.
If you do decide you need one,i have a zx9r
carb fuel pump that i am going to put on ebay.
I am busy changing over to injection atm,so its
not needed any more.Its still
on my car but it is coming off tomorrow.
Andy.
How much posted mate? Prob be handy to have.
u2u sent Lewis.
