Need a propshaft for my xflow powered Striker. I'm running a live (english) axle and needs to be 645mm long.
Chris
might be able to help you there... ill check tomorrow and let you know
Are you are running a 4 speed gear box? If so I will measure one I have in garage
Chris
Needs to fit between a xflow 4 speed (thinks its called a type 2) and a english axle. Measured betwween the two and its 645mm.
Chris
just measure my spare one and its overall 960mm long, was used with a 4 speed box with 16 spine end on it, may be of use if correct uj's if you want to modify and shorten it?
im sure it was a standard escort english axle, but ive taken some measurements on the first photo if you want to check it fits your axle, UJ's
feel good and both have grease nipples
after £25 + postage which is about £8 for a 3-5day parcel
Thanks for the info. Will check and see how much its going to cost to shortened and get back to you.
Chris
[Edited on 27/2/12 by cfc999]
