After a set of Weber twin 40's or 45's and mega-jolt ignition for a zetec due to giving up with mega-squirt
Prefer a clean set of carb's if possible as i will most likely sell the car in the summer
Ive a set of twin 40s i decided not to use,they are on a thin pinto manifold too!
They do need a little bit of work.
Aaron
I have a set of 40s on a zetec manifold bit to heavy to post though used them until I switched to bike carbs
Austin man would you send if i arranged a courier as depending on price i may be interested nsend me a u2u if you like ... Thanks
