As above,
has anyone got a zzr1100 oil cooler? i had bought one however the courier has lost it, cheers!
I have a oil cooler and pipes not from a zzr if it's any good
[Edited on 17/2/14 by kj]
Did you get sorted? I have one but the fins are pretty much buggered. I've come up with a better solution if you'd like to see what I've done/in process of doing.
As per our prev discussions this is what I did before selling you the engine.
Was modular so I kept most of it.
Cost about £60 plus rad cost.
http://www.zzr-international.co.uk/viewtopic.php?t=11574&p=94422
i should have redone the hole oil cooling system like what youv posted a few times david, but I've already welded brackets for the standard cooler. if oil temps are an issue this year i will be going over to a customer cooler using your link, ta very much.
