English Axle Large Diff Flange
Neb - 4/4/14 at 11:44 AM
Wanted:
English Axle Large diff flange - should be about 109mm across the flange.
Can pay via paypal/banktransfer etc.
TIA.
myke pocock - 4/4/14 at 03:00 PM
Yep, got one with a good Hardy Spicer in it as well. Make me an offer.
Neb - 4/4/14 at 04:06 PM
Apologies - I require the flange that bolts into into the nose of the Diff. Not the propshaft flange/coupling.
Thanks though.
[Edited on 4/4/14 by Neb]
bigfoot4616 - 4/4/14 at 08:37 PM
assuming you mean the pinion flange i think i have one. can check the size but i know its bigger than the one i'm using on the car.
Neb - 5/4/14 at 07:51 AM
Yup that's the one! Would be appreciated.
bigfoot4616 - 6/4/14 at 10:58 AM
it measures about 107mm across the flange, PCD is 90mm.
it was attached to a spare diff i got with the car so i'm assuming everything is ok with it.
no use to me as the small flange is tight as it is.
[Edited on 6/4/14 by bigfoot4616]
Neb - 7/4/14 at 07:33 AM
Thanks Big Foot - you have a PM for Payment.
