Hi guys,
I'm after a set of decent quality dampers for my Fury. Must be 12.5" open length, and minimum stroke of 90mm (100mm+ preferred). With or
without springs is fine, but if you have some 160-170s and some 110-120s to go with them that would be ideal.
On a similar note, they need to be valved for those sorts of spring rates, otherwise I'll need to factor in a re-valve to the cost...
Single or double adjustable fine, prefer rose jointed ends rather than bonded bushes but not too fussed as I can convert. Ideally need to be a
straight fit for 1/2" bolts but if not don't worry, I can make up some adaptors.
Many thanks,
Adam
[Edited on 26/8/15 by AdamR20]
