Does anyone know where I can get a short 300mm ish serial lead, I just want to run it from the ecu into the glove box, but not have a metre + of cable
coiled up in there.
Cheers.
Pete.
You can buy the plug heads and wire from RS components and make your own... search for "D-Sub connector"
Or your local Maplin.
Cheers guys, the d sub search found me the plugs and ribbon cable which will be ideal.
Thanks.
