Hi there, I'm trying to find an inner tripod style cv joint that is 22spline on the bearing and 26spline for the diff.
I'm building a 2nd hand kit (Luego velocity) and it came with some driveshafts which when I've just tried to fit the inner cv is only 23
spline so do not work with the diff, I picked up a full set off driveshafts and diff to sort this issue but one side (passenger) have switched over
fine onto the driveshaft but the drivers side is a thicker driver shaft so I can't use the cv's
Only other option would be to get the driveshaft shortened.
Hopefully someone can shed some light on the cv'S as I have no idea what I need to search for them!
Thanks liam
