Trailer wanted
CTLeeds - 15/11/18 at 08:52 PM
Ideally looking for a twin axle flat bed as I don't have much width to play with in my garage. Min bed width 6ft, max overall width 6ft 8". Max overall length 16ft.
Thanks in advance.
Chris
Barksavon - 16/11/18 at 06:27 PM
I've got a single axle trailer which you may be interested in although overall width is 7 '4" and overall length ( tow hitch to end of bed) is 6'6" .
I've only used it once to take my Avon to a track day.....blew the engine up and not got round to putting my replacement ST170 in yet so it can go.
Let me know if you want more info
CTLeeds - 16/11/18 at 06:39 PM
It won't fit unfortunately. Thanks though.
Chris
jeffw - 16/11/18 at 08:57 PM
This might suit
http://www.uphillracers.com/showthread.php?t=16208
CTLeeds - 16/11/18 at 09:06 PM
I've contacted them, thanks for the heads up.
regards,
Chris
CTLeeds - 16/11/18 at 09:50 PM
Again, It's too wide. Still on the lookout...
Chris
Barksavon - 17/11/18 at 08:08 AM
Think you may struggle to get a 6' bed width with a max overall of 6'8" , that only gives 8" for wheels. ..unless you can find one with wheels positioned under the bed?
CTLeeds - 17/11/18 at 08:54 AM
Yep, that's exactly what I'm after.
rusty nuts - 17/11/18 at 05:09 PM
I've been looking for a trailer that will fit in my lockup , the only one I've seen so far has removable wheels under the bed and a removable drawbar , unfortunately it has no brakes
jeffw - 17/11/18 at 07:11 PM
This is the only one I'm aware of which will fit the bill
http://www.allytrailer.co.uk/home/storage-applications
5' 11" wide, 160Kg unbraked which leaves you with 590Kg for the car on the trailer.
[Edited on 17/11/18 by jeffw]
CTLeeds - 17/11/18 at 07:30 PM
This is the sort of thing I'm after (just not in Devon!)
https://www.ebay.co.uk/itm/twin-axle-car-transporter-trailer-Had-Little-Use/323551442040?hash=item4b552b3478:g:5bEAAOSwi7Vb7X6X:rk:27:pf:0
