Does anyone have a 3.92 LSD and drive shafts off a sierra they want to sell?
Darren
Might have a 3.62, shafts and brakes, all fully re-conned and painted for sale soon...but won't be cheap.
Seen them go for £200 plus on the 'bay.
Pat...
got some drive shafts (off a non-lsd - will they fit a lsd?) for £30 if u want
IIRC all bolt on drive shafts are the same.
Pat...
I've already got push fit drive shafts, just need a 3.92 LSD to go with them, or if someones got a LSD with lobros then that would be good as
well.
wilkingj has one for sale. See for sale section.
don't think ford made a 3.92 lsd for push fit driveshafts and the only lsd 3.92's were on late dohc 4x4's, you need to get an lsd dif
and put the internals on the 3.92cwp you already have.. someone has had this done for about £80 iirc
Ned.
[Edited on 24/1/05 by ned]
Still looking for 3.92 LSD, what ever drive shafts.
Darren
Keep looking in your local 'Free-Ads' as this is where I managed to pick mine up from!
(3.62 LSD c/w driveshafts, hubs and calipers for the princely sum of £50!)
Andy.
You can use push in driveshafts on a bolt on lsd diff.
Take the back plate off and remove the circlips that hold the bolt on input flanges on. You can then take the flanges off to reveal splines the normal
push in shafts will go into.
HTH
G
Thanks Mr G, that means I can stick with the shafts I've got, excellent.
Still looking for LSD 3.92 though.
[Edited on 31/1/05 by sdv builder]
Just taken the flanges off the diff and the push in shafts do not fit, they're too small. Lobros it will be then.
