Trying to find a 2" version of the one in the pic , lovely and thin and smooth (like me)
The 2-1/4" I have won't tighten down onto my link pipe/ silencer joint.
NOT Mikalor or others with raised edges.
Am I right in thinking that as long as the clamp screw is not contactable by "the sphere" then with such a small stand off from the main
pipe then thay are SVA proof?
[Edited on 5/6/06 by ReMan]
I have seen these, can;t remember where though, CBS maybe?
or ebay: http://cgi.ebay.co.uk/Vespa-and-Lambretta-Stainless-Steel-Exhaust-Clamps_W0QQitemZ8072117663QQcategoryZ25640QQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/Exhaust-Clamp-FULLY-STAINLESS-STEEL-up-to-43-mm_W0QQitemZ8065433332QQcategoryZ25623QQrdZ1QQcmdZViewItem
similar but not quite the same; it may be possible to replace the nuyt.bolt by the cap head bolt.
http://www.powerengineering.co.uk/mikalor/
You can order any size you like and they take cards over the phone.
I got mine here, the dog's bits:
http://www.merlinmotorsport.com/product_info.php?cPath=1723_1724_1725&products_id=873
If no luck from any of the previous answers try your local motorbike shop they usually stock a full range of them!
cheers
We went for the full stainless ones from this guy Linky
Should be arriving anytime now will let you know what they are like when we get them.
HTH
Ed
Ed
might be a daft question, but have you tried MK?
MK sportscars : 01909 731187
MK engineering : 01709 815740
would think sportscars would be a better bet.
tom
tom
Regards your SVA question, if the clamp is contactable by "the ball" then you will fail. Turn the clamp so that the raised parts are pointing at about 45 deg's towards the car, (downwards), hope that helps. atb Chippy
Will Mikalor fail the SVA then?
If so I've wasted my money!
Stu
Mine didn't.
Nor mine - but I did fit it with the clamp at the back where the tester's ball can't reach it (ooeer!)
