One of my sva fails was to do with my seat/rollhoop. They are one and the same. I did put roll cage padding (aka pipe lagging) but the tester said it
must be a "manufactured finish".
I have bought some vinyl and heavy duty thread, but I can't find anyone to lend me a machine.
I have this week off and I am trying to beat the clock. If I email my tester he said he would fit me in to do a retest and hopefully if that gets
done, I will be able to persuade wimbledon dvla to see my car this week aswell
I know that I am being optomistic, but I have got to try!!!!!!!!
Even better would be someone to do it for me for some beer tokens, but they would have to come to me!
Desperately yours
Martin
(Since these photos I have stuck some foam over the top hoop)
rollhoop
[Edited on 2/7/2006 by nitram38]
It was 2 years ago now but we got away with pipe lagging completely wrapped with black Insulation tape to give it a better finish. Not sure if thats
what you tried the first time.
There is some external pipe lagging used in industry thats wrapped with rubber, you cut strips of rubber off and wipe the over lapping edges with
white spirit or thinners (that type of solvent) and then just hold them together for a few seconds while they stick.
Probably not that expencive and should look more profesional.
I have already spent £40 on vinyl, thread and velcro
I would prefer a pro job as everyone will see it.
Aah fair enough, thought it might have "blown off" on the way home from the SVA
If your holding in on with Velcro could you glue the velco to the back of the Vinyl, migh be a last resort.
I bought an old one from a flea market for £5 and it gets used for this kind of stuff as the wife didn't like the idea of sewing car stuff with her machine. You're at the wrong end of the country for mine but if you get round the car boots and find one they don't take much mastering. I put a new zip in my favourite shorts the other day as well . If it's just a simple sleeve you want to fit over and velcro in place it should be easy enough.
I want a slip over cover that can be velcroed down the sides below the hoop.
Looks more and more like a hand stitch job
There will be a fair bit of sewing around the hoop and on seams to make it look neat. Also the velcro will need to be sewn in.
You make them inside out then the seams disappear when you turn them. Velcro can be glued but caravan suppliers sell it in self adhesive with matched lengths of hooks and loops, you can buy it by the foot.
As pete says, use an old machine such as a Singer, they can sew this kind of stuff with no problems, whereas the posh modern ones seem to be quite
delicate. My mum had to send her Husqvarna machine back after trying to sew my motorbike seat cover.
A quick look through your local Freeadds etc. should turn up something for a few quid.
Cheers Gents
No takers on someone doing it for me then?
