sealed beam inc sidelights
locoboy - 9/1/07 at 09:59 PM
Hi im after a set of sealed beam units with side lights.
Anyone got a spare set for sale? or know where i can get a locost set!?
I have the casings i just need the sealed units themselves.
[Edited on 9/1/07 by locoboy]
snippy - 9/1/07 at 11:45 PM
I recently upgraded from sealed beams to some halogens as one of my sealed beams had blown. However i`m pretty sure I still have the other sealed unit boxed up and it was in full working order if 1 is any good to you?
Nick
DavidM - 10/1/07 at 01:17 AM
If they're still going Lolocost are very reasonable for sealed beams. Generally you need a plug in side light loom for the side light and it shines through a small window in the back of the sealed beam. Unfortunately the looms are often about £9 each from those stalls at kit car shows.
Bluemoon - 10/1/07 at 08:47 AM
Might be an idea to try your local motor factor, you might be suprized..
Dan
02GF74 - 10/1/07 at 09:36 AM
don't recall ever seeing one with a side lamp in there .... so as above ^^^^
I've got a pair you can have for free, regular 7 inch(?) ones from a Land Rover - same size as MGB, mini and a plethora of other British cars from the 60-80s.
Peteff - 10/1/07 at 10:53 AM
All the old Minis had them. 7" are still freely available and you can get H4 conversions for them from VWP or similar which are a massive improvement. There's a 7" sealed beam on there with glass pilot window for £7.69.
locoboy - 10/1/07 at 11:35 AM
Cheers for the suggestions, good info as usual.
Got a a pair on order now.
Thanks again
