Any one got a inlet gasket for a zetec sitting about ? needs to be reasonable condition,
Need so that I can make a template out of it in steel so no requirement for it to be new just unbroken.
I can send you an AutoCAD dxf file of a blacktop inlet gasket (although there isn't a gasket on a blacktop) it hasn't got the recesses for injectors in it, just the oval holes. It is as yet un-tried, a paper print matches the ports, but I haven't yet had a plate machined from the file
Yes ok that should help - I have access to autocad.
B.T.T
