hi,
im hoping some people will have zetec engines and will be throwing most of the efi stuff away...
basically, on the EFi stuff, screwed to the fuel rail will be two pipes, that have a male style connector on the end ( the pipe is prob about 30 cms
long ).
this pipe push fits in to a female connector ( the type where you have to sqeeze together two tabs to pull the pipe out ) on the end of the main cars
fuel lines. its these i need - with about 2 -3 inches of plastic fuel pipe attached...
Im hoping someone still has some somewhere......
i can provide pictures if need be.
Ian.
U2U sent
it looks a little bit like this... but imagine that instead of a bend, its straight.
[Edited on 16/7/07 by saigonij]
U2U sent...
