Evenin' all
I've lost the large washers used when bolting the driveshaft flange to the hub. Does anyone have any spare for a few beer tokens.
You mean the washers that go under the hub nuts ?
I'll have a look.
Hi Macbeast
Yes - that's the ones!
OK, I have new bearing sets for front hubs. I know they include hubnuts but not sure about the washers. If there are new washers the old ones are
yours, but it'll be tomorrow before I can get them.
Will let you know asp.
Front washers are different to the rear ones for push in shafts on mine.
front or rear ?
if rear, push-in or bolt-on ? (don't know if they are different)
I should have some spare rear ones from a granada with bolt-on shafts
Rear for bolt-on type (lobro) shafts please.......
[Edited on 9/10/07 by TimC]
I'll have a look later and get back to you....
Sorry M8, had a look and the bearing kits do not include new washers so I'll be needing my old ones myself.
Hope someone else can help.
Still need a pair of washers ??
I've got 1 spare set (sorry pics a bit big)
if anyone wants to know they mesure:
45mm outside diam.
5mm thick
~22.2mm hole
