Rack extenders
SyKaTurbo - 15/10/07 at 12:10 PM
Seems m14 is an odd size and none of the lads with lathes have them
Anyone got a set kicking around before I go buy some?
takumi - 15/10/07 at 12:20 PM
I made some thread adapters for my rack to convert to 1/2" unf for my rose joints.
I bought a tap&die set off flea bay , in a big carry case, goes from M6 to M24 ! with M18x1.5mm too.. well worth the money, which at the time was I think £40-odd with delivery
This is the cheapest same set I could find.
http: //cgi.ebay.co.uk/SEALEY-AK303-Tap-Die-Set-45pc-Metric_W0QQitemZ160168731442QQihZ006QQcategoryZ633QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
atb
tak
designer - 15/10/07 at 12:59 PM
The secret with taps and dies is only to buy what you will need.
Any tool factors, and every town has one ot two, will sell singles.
You will get a better product and save money.
The same for reamers.
welderman - 15/10/07 at 02:46 PM
try K supplies in chorley, on eves lane. 01257 267170
ask for graham. if your struggleing i can put it on account
pewe - 15/10/07 at 03:27 PM
If it's only a small amount you need I extended the 12 or 13mm penetration of the rod into the rod end by welding a suitably threaded self-coloured nut onto the rod end (tack it first when screwed onto the rod to ensure the threads line up). That gives it enough strength - (can't claim that as an original idea - credit to WestF27) his seem to be OK - mine as yet un-tested.
Cheers, Pewe
[Edited on 15/10/07 by pewe]
gingerprince - 15/10/07 at 04:15 PM
Wot, like these?
mr henderson - 15/10/07 at 05:09 PM
This is good advice. I will add to it that what you are looking for is taps in HSS (high speed steel) rather than the much less satisfactory 'carbon' or 'high carbon'
