Weber 28/36 Carb
stevetzoid - 15/4/08 at 12:00 PM
Hi All,
I am desperately looking for an Italian 28/36 weber carb, I race in the Locost series with the 750 Club. I have had a stuttering problem for a long time and it is hurting me big time. I need to find an original one from an escort 1300 gt or similar if any one can help that would be great. Thanks in anticipation.
Steve Evans.
Mr Whippy - 15/4/08 at 12:05 PM
a picture of the offending item if it helps -
have you checked the accelerator jet, that will cause stuttering if blocked when you try to accelerate. Rescued attachment carb.jpg
Dingz - 15/4/08 at 01:07 PM
What size chokes does it have? I have one in the garage with smaller than 26/27 which is the norm for the 2l. Will look this evening to see what size they are.
stevetzoid - 15/4/08 at 01:23 PM
Hello, I think the chokes have to be 23 and 24 mm. From the 1300gt and sports etc.
Thanks Steve.
richardlee237 - 15/4/08 at 02:01 PM
The carb you are after is a 32 DGV NOT a 32/36.
the 32/36 has 26 and 27 mm chokes. You need 23/24 mmchokes.
There are tons of 32/36 around but 32 DGV seem as rare as nuts on a rocking horse.
richardlee237 - 15/4/08 at 02:05 PM
A useful little linky dinky
Linky
The Baron - 15/4/08 at 03:36 PM
I got a brand new carb from a place called 'fast road cars'
Linky (i hope!!!) below
http://www.fastroadcars.co.uk/
Dingz - 15/4/08 at 06:00 PM
Its a 32 DGAV 5E with 24/23 chokes
, is that good enough? its all there apart from the U bracket the rod linkage clips into. Rescued attachment 32dgav.jpg
stevetzoid - 15/4/08 at 11:03 PM
does it have made in spain or italy stamped in the case above the float chamber, visible from the top looking down on it minus the air filter.
Dingz - 16/4/08 at 05:40 PM
Italy, is that Italian enough?
richardlee237 - 17/4/08 at 11:27 AM
If you really want a new one, see here
[url=http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130208039141&mpt=1208431273151&tGUID=6fdc37f51180a09c1875f1c5fff575e9]linky[/url ]
