R reg is 77 so it's very likely to be an age related donor plate and maybe the DVLA screwed up the V5 paperwork - not unknown for pre SVA builds
where things were even more confused than now.
It says Locust (which is a plywood and ladderframe chassis 7 lookalike). So I suspect one of those has given up it's identity to a MK build.
I call ringer.
[Edited on 29/12/09 by iank]
I have never seen the car it says from hull but i think its some one off here
Jacko
i would say its a indy, but with the log book of a locust.
Mk use to make the locost do you think he has put [ locust ] and not locost by mistake
i like that he has put that there is so much he can say about the car, then says nothing at all about it
Hmmm.
Engine's an unusual choice - may well have come out of a Locust.
We've seen it all before - BEC MK crashed and reborn with an S2000 motor anyone?
TC
Dont forget, you can call it whatever you like when you SVA.....
But, i think its a ringer, but id still probably buy it if i had the cash.
When was fiat twin cam first madfe? age related using the engine??
If not then its a ringo star,
Clearly a ringer. Obviously an Indy chassis etc from the description but registered as a Locust
One car with the identity of another is a ringer - how can it be anything else?
People continuing to do this sh*t will only give us genuine builders a bad name and make it more difficult for us to put our cars on the road in the
future
i reckon its the other way round, i think its a J&C Locust on a dead MK's papers. Ladder frame chassis with 3/4" marine ply body skinned with ALi, built one myself in the 80's. I think the hint is the width of the cappings on the body sides
Its worth mentioning that alot of locusts were re-chassied into book frames before SVA came in. My car was originally a Locust and was re-chassied in 1995.
id suggest ringer.
BUT, you are allowed to replace all parts if necessary, i just dont think you can use a different chassis from the wrong manufacturer.
Now he could argue that it was originally a locust, then previously rebuilt before sva onto a spaceframe, than more recently rebuilt onto an MK indy
chassis. This would not be far outside the law, maybe even legal.
However, id never pay £6750 for it even if it was legal!
Originally posted by JoelP
id suggest ringer.
than more recently rebuilt onto an MK indy chassis. This would not be far outside the law, maybe even legal.
DVLA rebuilt vehicle rules
The original unmodified chassis or unaltered bodyshell (i.e. body and chassis as one unit - monocoque); or a new chassis or monocoque bodyshell of the same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt).
Not a Locust all the wrong shape. I should know as I made one.
