Rover v8
EDIS 8
2 of
Also have the following for RV8;
Large style starter.
Flywheel.
SU Carbs
Plenum & Injection setup.
Refirbed Standard Heads.
Some grubby looking standard rocker covers (need blasting)
Grubby looking standard heads.
Oil pump
Water pump
Standard Dizzy
3.5 Block - needs relining due to pitting and scoring in liners although have proof of age letter from land rover, will run but will be smokey as funk
after couple of thou.
3.5 crank, pistons & main.
Did you finish the Avon mate ?
ALMOST... we're building a garage for it at the moment. But just bought a camper for the summer so its still not OTR!
Prices on the list may help.
