Cheap enough to buy Four
http://www.halfords.com/webapp/wcs/stores/servlet/SearchCmd?srch=colortune&action=search&storeId=10001&catalogId=10151&langId=-1
but does anyone still use those things ?
What's a 'carb'?
I do! How do you check the mixture otherwise, especially with carbs?
They look something like this
Originally posted by fesycresy
What's a 'carb'?![]()
What's a 'carb'?
Good spot, One reserved
Originally posted by ReMan
Good spot, One reserved![]()
I always went with 'if it smells right & sound it'll be close enough'
then take it to the garage down the road to use the gas analyser when I get the chance...
I'd be interested to hear how close you can get a match on 4 pots with just visual feedback. Used to own one of these but I could adjust the
mixture and the timing so far without being able to see a difference it was mental.
They are like fuel injection that you can fix when it goes wrong.
The trouble with colour tunes though is that you can only really tune the idle mixture, I did have one years ago but never really found it much use
apart from idle adjustments.
Paul
I already have one, have reserved three moreCan you imagine how much easier is to set carbs with all of them fitted at once
