linky
ETDWM
happy bidding!
you have u2u
ch1ll1 - so do you
I'd be careful with stainless wishbones, they can work harden, particularly in the HAZ and leads to cracking.
I hope you're not trying to do these commercially Doughie, and if you are switch to DOM or CDS. If you want to be flash then use chrome-moly.
Also, there appears to be insufficient, or no, setback on the top wishbones to give proper castor.
If someone sold these to you, return them and ask for your money back.
Syd.
....Many people adjust the chassis to re-position the brackets rather than requiring extra offset in the bones.
Not quite as simple a solution as it sounds, as it requires those four front tubes to be moved. That is if you are putting in the extra 20mm setback needed.
