NTDWM
Interesting build and use of materials ??
Ebay
Link
[Edited on 2/6/08 by neilj37]
Ah yes the Locust - ladder chassis and plywood body.
Probably not the best handling car out there
At least the plywood body will be easy to keep in good condition - 20L of Cuprinol and your sorted for 5 years
I've not studied the Locust construction, but there is no inherent reason why a properly designed and made plywood body shouln't be very
stiff, and at a reasonable weight.
John
Originally posted by mr henderson
I've not studied the Locust construction, but there is no inherent reason why a properly designed and made plywood body shouln't be very stiff, and at a reasonable weight.
John
having built one of these i can vouch for the fact that the body adds little or no rigidty to the chassis, not does it need too!! the bl**dy thing weighed a ton and would put the forth road bridge to shame. That said it was my first intro to kit cars and was a pleasant enough build with an ok end result, the handling was ok compared to cars of its day. the one nice thing was that the complete body build including ali sheeting only took 2 days.
Locust? I thought they were called Morgans?
i wonder if a wooden locost would float?
Originally posted by jacko
NO steel chassis and plywood top must be a CARAVAN
