am i right in thinking you can get drills which drill a hole, and then half way up the shaft its got some kind of cutting thing to allow you to cut slots? or am i way off?
you are right but they are only good for plastic really. if you want a slot best get it milled out using a milling machine
Water jet cutting! Ideal for slots.
i thought as much about the drill type things... cheers guys, i know my drilling's going to end up being out. big washers needed i guess!
mmm waterjet cutting. if i had one i would
also, if i had time, and knew how to do a CAD drawing i would. but i don't and i can't, so for
now, drilling it is
once the cars build and running and legal, i'll look to get some bits water/laser cut properly, but for now hand tools are the way
Chain drilling and file it is for you then
Those drill bits are good for ali and thin steel but 5mm steel it will blunt straight away.
Drill hacksaw then file.
Originally posted by blakep82
mmm waterjet cutting. if i had one i wouldalso, if i had time, and knew how to do a CAD drawing i would. but i don't and i can't, so for now, drilling it is
Just get an adaptor for your pressure washer, and cut it by eye. CAD/CAM is for wimps. Dead simple!
John
Drill and jigsaw
i *think* i've managed to do a drawing in dxf format. it seemed a bit too easy though lol
Why dont u just give me an accurate drawing on fag packet and i will job it with a slot drill ya dobber
Shug
^ lol i keep forgetting
Drill files work but they are slow and not very accurate, snatch Shug's hand off
Originally posted by Peteff
Drill files work but they are slow and not very accurate, snatch Shug's hand off![]()
drill and files are perfectly accurate, even down to 0.02mm if you've got the time and the skills
John
ROFL
Drill hole each end, 1mm slitting blade in angle grinder, and cut the slot away. You might need to finish each end of with a pad saw and hacksaw blade, but its a lot less hassle than chain drilling![]()
