Anyone ever built one?
I have an upstairs bathroom we were thinking of turning into a wet room. To do this I was considering sheathing the whole floor and about a foot of
the lower wall in 5mm of GRP then tiling over that, especially if I stippled the surface before the resin cured to give the tiling grout a good key.
To me that would be the best and easiest way to guarantee it would never leak and I could easily mould in a drain for the shower. The floor is large
chipboard panels rather than floorboards and the walls are plasterboard.
Any suggestion or tips?
oh I've already been told car parts are banned
they normally do it with some sort of a vinyl floor don't they? its not vinyl, i can't remember exactly what it is, but some sort of pastic
I've seen the stuff and it looks like some sort of tanking as used on basements
I like the idea of using GRP as it's easy to apply, cheap and can't ever leak
can't leak, unless it cracks... as long as your floor's solid it should be fine i'd think, although i've never built one!
I would recomend changing the flooring to a marine ply, then laying either an Altro Marine or Polyfloor Suprtech vinyl with coved skirtings.
Ensure floor is laid by an approved installer and you will get a manufuacture approved warraty against leakage - drawn and specified hundreds of these
in the old days
Ensure floor is laid by an approved installer and you will get a manufuacture approved warraty against leakage - drawn and specified hundreds of these in the old days
If you sheet out the whole floor, how do you access the waste trap, or other underfloor plumbing fittings?
I don't think the sub floor material will matter at all if you are laying 5mm of fibreglass - it will have enough structural strength to avoid
cracking anyway.
Regards
Hugh
we got one recently, they use a kinda resin stuff first then tile on that...
AFAIK Fibreglass isn't waterproof, it's the gelcoat that does that trick. I know old fibreglass boats can have horrible de-lamination problems due to water having got into the structure.
I do it for a living, (bathroom, shower and wetroom installations).
Like anything else, do it on the cheap and youll cost yourself a fortune in the longrun. There is only one way to do it and thats the right way and
fibreglass aint it!
As mentioned above
Altro marine / Polysafe or similar forms the floor finish with a cove former to bring it up the wall to meet with the tiling.
A Harmer floor drain takes care of the waste.
You can also buy a GRP shower tray which is 19mm or 22mm thick around its perimeter. This replaces the floorboards and has a falll to the centre. The
harmer drain goes into this and the altro marine goes on top.
This is all on the basis that you have a nice deep joist running in the right direction to allow the waste to get away.
Otherwise you're into pumps and all that nonsense.
(Yes, I'm involved in this line of work too.)
