What welder for £300?
flak monkey - 28/10/09 at 01:15 PM
On the hunt for a decentish mig. Not used every day, but will get a fair few hours use each month I would say.
I dont have the cash for a Portamig, and I think they may just be overkill for what I am going to do.
What are the Clarke 151TE or 160EN like these days? Thinking the dual polarity of the EN may be useful so I can do gasless if needed.
Also found the Lincoln Handy MIG, ERP Supermig 150 and the SWP 170C all the same sort of price new.
Basically the budget is £300 max, willing to go secondhand for a better machine as long as parts/spares are easily available.
[Edited on 28/10/09 by flak monkey]
rayward - 28/10/09 at 01:23 PM
ive got the clarke 135te turbo, and its been excellent,
does the 150 amp one work off a standard 13amp plug now, i'm sure in the past it needed a 15A supply
hth
Ray
flak monkey - 28/10/09 at 01:26 PM
Yep ideally needs a 16A supply, but thats no problem as I have a 16A socket in the garage anyway
speedyxjs - 28/10/09 at 01:30 PM
I have a 151te. Great welder but i dont really have anything to compare it to.
MikeR - 28/10/09 at 01:32 PM
I happily weld with the clarke 151 at full power through a standard plug.
Seems like an ok welder to me, but if you can afford it i believe the 160 is an all together better machine.
turbodisplay - 28/10/09 at 01:32 PM
I have the clarke 170A version.
Works well, good wire feed, as I learned from my last welder!Darren
paul the 6th - 28/10/09 at 01:36 PM
151te here, great welder (used one from the bodyshop over the road for 5 minutes once - it was horrific! proper terrible cheap thing). The clarke is nice, had it for a year & no problems yet
blakep82 - 28/10/09 at 02:16 PM
mine didn't, kept blowing fuses. guess some are ok, some not, nut the clarke one is a great machine for the price
JekRankin - 28/10/09 at 02:54 PM
I bought a 160 after reading good things about it on www.mig-welding.co.uk/
Been very happy with it so far. Its my first welder though, so I've not got anything to compare it to.
The VAT free days at Machine Mart are a good time to get one.
Steve Hignett - 28/10/09 at 09:20 PM
151te and no probs whatsoever.
Gav - 28/10/09 at 10:41 PM
160T here and its a cracking bit of kit for the money.
flak monkey - 29/10/09 at 08:18 AM
Whats the difference between the 151EN and the 160EN?
The 160 seems to have a lower open circuit voltage which ISTR is better and a slightly higher duty cycle.
Other than that they look virtually the same other than the price?
MikeR - 29/10/09 at 08:27 AM
euro torch.
Benzine - 29/10/09 at 08:32 AM
scottish electricity is more aggressive and drunk than english
Gav - 29/10/09 at 02:50 PM
Yep you right about the OCV and duty cycle, IIRC the other difference is the 160 comes with a shelf on the back for refillable bottles and an industrial regulator rather than one for disposable bottles, also the torch is a euro fitting.
[Edited on 29/10/09 by Gav]
flak monkey - 29/10/09 at 03:12 PM
Are you sure its a euro torch? Looks like all the other std fixed ones to me?
I know you can convert them but didnt think they were as std?
Gav - 30/10/09 at 04:15 PM
Actually your right, my bad, its not a euro torch fitting at the welder end but does take the euro torch style shrouds the ie the slip over ones not hobby style screw on ones.
T66 - 30/10/09 at 10:46 PM
I have a SIP 150Turbo , before that a Clarke 120 which was much better than the SIP.
Ive recently bought a Clarke 195TEC on wheels, its excellent.
my SIP runs on a 25m extension lead from a socket 13amp in my kitchen...
Without any problems.
However the big Clarke now has a 40amp dedicated supply on a 10mm cable.
Clarkes are good value for the money, SIP I wouldnt have again.
Poor settings options & crap wire feed
other than that they are crap ....
Mark Allanson - 31/10/09 at 08:56 PM
David,
I have said it before, I have used a Clarke 140E since 1988 and it has been a belter, some professional use for about 10 years.
However I have been lucky, you would be much better off with a second hand industrial unit, from main names like Esab, Lincoln, Migatronic, Kemppi etc. They are a real joy to weld with, all parts are easily available off the shelf.
flak monkey - 1/11/09 at 11:49 AM
Well I just won myself a Lincoln SP170 on ebay
Should be a reasonable machine, seem to get good reviews. New they are around £700 so.
Interestingly they are also rather useful for MIG brazing... apparently
