Having just bought >>these throttle bodies<< from Scootz (ta muchly
) I now find myself in need of a welder. As you can see from the pics, there's an aluminium flange which needs some tubes welded to it.
Can anyone on here offer services or recommend somewhere to get that done?
Many thanks
i would give James a call and tell him Paul told you to call with the imp he is very good at alloy welding example of his work
his number is 07968329108 its your call good luck
that looks very neat - thanks!
