I know nothing about fixing up tin-tops with panel damage, and have only ever done bespoke fabricating for silly cars using a MIG.
Is it widely accepted that using a spot welder is preferable to using a MIG, since you can get into tighter spots, and 'hide' the weld as an
invisible weld pool where two panels touch?
Alternatively, I can see that you could drill out the old pot welds then MIG the hole back up using a form of rose weld.
Gary
MIG works fine, especially if you have one of the nice joddler tools that incorporates a hole punch. It may need a touch with the linishing disk to be invisible, if it matters.
I restore cars for a living now and I still don't have a spot welder.
I plug (rose) weld all areas that need to be "spot" welded, and seam weld in any areas that I am butt welding in to repair panels.
There are occasions that a spot welder would be useful, but the mig is much more useful for 99% of work.
I've always seam welded with the MIG then skimmed with some filler on my MOT jobs and worked fine for me...
filler.....a dirty word in my workshop!!
Does a job though!
You can actually get special shrouds for mig welding plug/rose spot welds.
There was a good page on the net written by a US guy restoring a VW camper van who experimented to find the best way to plug weld with a MIG. ISTR
he recommended clamping a stainless steel bar to the reverse side.
personally i prefer TIG for everything. MIG is faster but tig is more controllable and welds ally better.
Does a job though!![]()
Could you guys recommend a MIG please I'm fed up with trying to do small stuff with a stick welder - need it for all usual DIY car related stuff
- thinking of Clarke 150TE (turbo) Machine Mart £293 ?
The Clarke MIG welders are about the best of the "cheap" far eastern machines. Lots of people on here have them. Avoid the SIP/Cosmo
welders, they have a number of flaws that make them a PITA to use.
The 150TE will be more than adequate for anything you'd need to do on a Locost.
[Edited on 5/5/10 by MikeRJ]
Thanks for the replies guys.
So when I've drilled out some existing spot welds, should I make new plug welds in a different location, or should I attempt to use the same
holes, in which case I guess I need a backing piece - e.g. the stainless steel bar suggested above.
So gravity doesn't make MIG a pain... even if upside down?
Are there any tricks for minimising splatter and spark damage, other than lots and lots of sheets?
Gary
Using a flap wheel and NOT a grind wheel helps, it keeps the heat down so minimising heat distortion.
So when I've drilled out some existing spot welds, should I make new plug welds in a different location, or should I attempt to use the same holes, in which case I guess I need a backing piece - e.g. the stainless steel bar suggested above.
Much respect to anyone that can get a paintable finish without filler. MIG tends to be very hard compared to the surrounding steel - how do you get a good finish on this when using mild steel car panels that may contain compound curves? Angle grind it down with a keen eye and lots of skill?
Gary
Thanks for the replies on the MIG - think I will go for the Clarke 150T or 151T.
Ian
