Hi guys,
My Mig has been playing up, its not closing off the gas properly, i need a Solenoid like the one ive pictured below -
its a 220v Solenoid, 50Hz, 10Bar. - Manufactured by CEME.
Found a 230v one online, but i assume it wont work?
https://www.weldequip.com/gas-solenoid-valve.htm
Any help would be great!
[Edited on 11/6/13 by Benzo]
Why not? same spec, just different adapters. Probably find they will swap (no guarantee, but would be a reasonable assumption)
Gas solenoids are nothing special. Honest.
You should be fine. There tends to be that much variation in mains supply anyway, and there won't be anything clever in your mig machine to ensure exactly 220v.
Weldequip has them in a range of voltages, they are used in euro torch conversions. 220v is nominal, they handle anything up to around 240v. Have you tried a spot of oil in yours to see if it the valve sticking ?
The voltage tolerance is quite wide on the solenoids.
I used this.
GAS SOLENOID TO SUIT MIG AND TIG WELDERS, AND PLASMA`S CUTTERS | eBay
Make sure you install in the right direction or they'll leak. (ask me how I know)
Originally posted by Benzo
Hi guys,
give weld pro a ring and speak to Davy, i'm sure he could help you out with anything else. Sydenham Rd Belfast, County Antrim BT3 9DJ
028 9045 6232
[Edited on 21/6/13 by KELLSY84]
028 9045 6232
