Ø35mm kitchen cabinet hinge cutter?
nick205 - 10/1/19 at 11:43 AM
I'm currently fitting some doors to a kitchen style cabinet (I designed and made the cabinet myself and the doors were purchased).
The doors have Ø35mm partial holes cut in them for the hinges to locate in. However I could really do to cut 2 new new Ø35mm recesses in the doors to reposition the hinges to avoid some screws in the cabinet.
Does anyone have do this kind of thing for a living and can they recommend a suitable tool for doing the job please?
Budget is around £15-20 for what I assume must be a drill bit of some kind.
I have a drill and other tools available already.
Thanks,
Nick
richwill - 10/1/19 at 11:59 AM
Screwfix sell the cutters. Either use it fixed in a drill stand or use a router if you have one. Dont try to use it free hand in a drill you will make a mess of it.
Charlie_Zetec - 10/1/19 at 12:07 PM
You'll need a 35mm forstner bit on a pillar drill (bench mounted one will do, doesn't have to be a biggie). But as said, don't bother trying to do it with a hand drill - you'll end up making a horrible mess and buying new doors....
Schrodinger - 10/1/19 at 12:20 PM
And make sure you have a stop on the drill so it doesn't go in too far.
nick205 - 10/1/19 at 12:39 PM
Thank you chaps.
I have a bench mounted drill press (with a depth stop) and will take a look at Screwfix.
I certainly don't want to mess up the doors!
[Edited on 10/1/19 by nick205]
ste - 10/1/19 at 12:56 PM
Jig for aligning your hinge on the door side
https://www.amazon.co.uk/Concealed-Hinge-drilling-jig-mounting/dp/B003CLKRO8
Jig for the cabinet side
https://www.amazon.co.uk/Template-Kitchen-Bedroom-Bathroom-Mounting/dp/B00OZMIQK0/ref=pd_bxgy_60_img_2?_encoding=UTF8&pd_rd_i=B00OZMIQK0&pd_rd _r=e87ec6e2-14d6-11e9-ab29-0509c0f14552&pd_rd_w=JRdh2&pd_rd_wg=ktKeg&pf_rd_p=466c8fd0-3653-4c9b-86fa-f9bc8fd2ae35&pf_rd_r=N6TMBVC0WXYP 7D827V69&psc=1&refRID=N6TMBVC0WXYP7D827V69
Drill bit
https://www.amazon.co.uk/Draper-14037-Hinge-Hole-Cutter/dp/B0001K9PUU/ref=pd_bxgy_60_img_3?_encoding=UTF8&pd_rd_i=B0001K9PUU&pd_rd_r=e87ec6e2- 14d6-11e9-ab29-0509c0f14552&pd_rd_w=JRdh2&pd_rd_wg=ktKeg&pf_rd_p=466c8fd0-3653-4c9b-86fa-f9bc8fd2ae35&pf_rd_r=N6TMBVC0WXYP7D827V69& ;psc=1&refRID=N6TMBVC0WXYP7D827V69
myke pocock - 10/1/19 at 08:28 PM
Even using a pillar drill I would still clamp the door to the table. You could even clamp a straight edge (bit of 2 x 1) to the drill table and that will ensure you get the holes exactly the same in from the door edge. Still clamp the door down though.
