Does anyone know where I can buy those black rubber 'condoms' that slip over the end of exposed threads to prevent corrosion and sharp
edges? I'm looking for a couple to go over the end of some 7/16" threaded bar. Looking for the rubber/flexible type rather than the hard
nylon stuff (doesn't have to be SVA-compatible).
Thanks!
What you're looking for is called rubber hose
Thanks but I am after something with a neat, closed end, as it is clearly visible on the exterior of the car.
These are rubbery from tifosi and u can heat them up a get them over larger things.
Cheers Dan - that's the ticket!
