BO**OCKS
i was just filing my grp and have put a massive scratch across the bonnet, is there a way of reparing the damage or not?
regards matt
depends on the depth of the scratch. If you bring the bonnet to mk on saturday ( not this one ) and ask for me (paul) i will see if i can either buff it out or repair it for you
right cheers paul, are you at mk evary sat (when not at shows etc) as it wont be straight away that i bring the bonnet as i'm going to uni. maybe
closer to christmas, can i have an email address to contact you closer to the time (or just ring mk?
cheers for your help
As long as you can get hold of the gel coat, the repair should be easy! Very similar to normal paint work, but easier to finish!
