Small Portable Welder
JimSpencer - 18/4/07 at 11:01 AM
Hi
Need some advice.
Looking for a small welding kit that can live in the trailer for trackside repairs (Arn't mudwing mounts a pain..) I am wondering if you can get such a thing as an Oxy set that works off small (disposable?) bottles or a very small Mig, any ideas anybody?
02GF74 - 18/4/07 at 11:06 AM
portapak
JimSpencer - 18/4/07 at 11:09 AM
Ok, i'll define Small..
Able to carry in 1 hand, fit in the trailer with all the other rubbish etc etc.
StevieB - 18/4/07 at 11:15 AM
Just got a card through the door from machine mart - VAT off all clarke kit. Don't know if Clarke do anything suitable for your needs, but worth a look.
Peteff - 18/4/07 at 12:27 PM
You could look at the latest inverter migs. They are small and powerful and some will run from generator power. They are not cheap though.
02GF74 - 18/4/07 at 12:33 PM
ok then, some welding sticks and jump leads - then connect across car battery - the off-roading boys used this method for in the field repairs. Or is that still too big
Confused but excited. - 18/4/07 at 12:33 PM
B&Q used to do at little tiny gas set with disposable cylinders about the size of a milk bottle. I think the make was Bernzomatic. These are great for little diddy emergency jobs.
I would think that the heat output wasn't too great and the gas per litre is expensive.
As mentioned a BOC Portapak with the smallest bottles, on a little trolley or a frame with carrying handle is probably favourite.
davie h - 18/4/07 at 12:45 PM
stevie B
when does the deal at machine mart run out i was going to get my clarke 151temig at the weekend but might go today if it runs out before the weekend the only ad i got was spend over £150 and get £30 of vouchers
cheers Davie
UncleFista - 18/4/07 at 02:03 PM
Originally posted by davie h
stevie B
cheers Davie
We bought the same welder at the weekend, cracking machine.
I "think" that each Machine Mart branch has it's own VAT free days[1], when we went for the welder on Sunday, they didn't have the one we wanted (they did eventually, it was in the window) and said we couldn't go to another branch 'cos their VAT ree days differ...
[1] They seem to be invite only, we had to either show our postcard or sign in.
[Edited on 18/4/07 by UncleFista]
stevebubs - 18/4/07 at 06:22 PM
mini portapak
davie h - 19/4/07 at 08:02 AM
went into machine mart yesterday and asked the guy at the counter said they not doing the no vat deal for a few weeks so will stick with getting the £30 of vouchers UncleFista have you tried to run the mig from a normal plug socket and does it run ok
JimSpencer - 19/4/07 at 08:29 AM
Thanks All.
That Miniportapak looks just the job, though must go and find out about the Arc Welding with a Car Battery, that sounds really interesting..
Peteff - 19/4/07 at 08:54 AM
You'll not weld arch supports with the mini portapack, it will not generate enough heat for thick metal.
UncleFista - 19/4/07 at 04:39 PM
I've not done much with it yet, but it runs fine from a normal household socket so far. My brother has chopped and welded a sump up, so it's had a workout, but not at full power.
According the bods in the know HERE the welder is fine unless run at full power for a while on a 13 amp socket.
Check the forums on the welding site, we bought the welder as it's recommended by professionals on there.
It's soo much better than our old Snap-On 130, does welds to be proud of
Peteff - 19/4/07 at 04:45 PM
It's vat free day this Sunday and next at our local Machine Mart in Mansfield, not much help for you in Glasgow though.
davie h - 19/4/07 at 10:01 PM
thanks for that i will get it at the weekend and get the vouchers no doubt they will come in handy for some other tool i will need to get
cheers Davie
JoelP - 20/4/07 at 06:53 AM
i only get invites to the bradford branch, but i got a clark 160te welder last weekend, collecting today! You need to be on their list as they do the vat free sessions during normal closing times, ie sundays and evenings.
davie h - 20/4/07 at 09:07 PM
e bay
jim found this on ebay i dont know if its any good for what you need but it might work
[Edited on 20/4/07 by davie h]
stevebubs - 20/4/07 at 11:56 PM
I've had one for about 2 years now. Runs fine from a 13A plug unless you're welding something really thick on full power. Then it just blows the fuse.
It's fine for 99.9% of jobs, though....
davie h - 28/4/07 at 12:46 AM
got my mig today and had a quick go before i had to go to work works brilliant very good welds i should only need a few go to get the best setting and away we go cant wait to get started
p.s. thanks to all for the advice
