Fuel transfer pump
RickRick - 6/3/08 at 12:52 PM
Can someone point me in the right direction for a cheap fuel pump preferably 12v, it'll be used to empty a fuel tank Max 20 liters back to a jerry can. The tanks too low to syphon it out
worX - 6/3/08 at 01:01 PM
You could have a look at ONE OF THESE if you want to use it over and over...
They also do a drill operated one for a tenner, that would probably do for a one off???
RickRick - 6/3/08 at 01:14 PM
i should have said, it needs to have a hose so we can thread it into the tank though the filler neck to drain it
Mr Whippy - 6/3/08 at 01:35 PM
Jack the car up?
You don't need much height to siphon, fuel
Yummy stuff too
Phil.J - 6/3/08 at 01:47 PM
I use a car fuel pump with a small 12v battery, swith and plastic hoses.
Has worked well for years both at home and in the paddock.
