sand blasting aluminium?
Miks15 - 27/6/08 at 09:45 PM
I wana clean my sump up abit but its got some awkward shapes to it so i thought blasting it would get into all the little bits.
Can it be done?
clairetoo - 27/6/08 at 09:50 PM
Yep - just be sure it's VERY clean inside before you re-fit it !
Miks15 - 27/6/08 at 09:51 PM
wkd cheers claire, ye i figured i dont want sand flwoing around my engine
liam.mccaffrey - 27/6/08 at 09:52 PM
I have done it with ali components before they come up lovely like a brushed finish.
try it out first on a test piece!!!!!!!!!!!
make sure the blast media is not too abrasive and the pressure not to high or you could destroy you part.
you might want to bolt some hardboard to the mounting face so as no to damage it
StevieB - 27/6/08 at 09:58 PM
Alternatively, find your local vapour blasting firm and get them to do it - nice clean finish and should be less risk of damage
Dave Ashurst - 27/6/08 at 10:09 PM
... or bead blast.
The media needs to be softer than the metal*, otherwise fine particles can get embedded in the surface. When its get hot the fine embedded grit can be released into the oil.
*i.e. I wouldn't grit or sand blast metal that will be in contact with engine oil.
[Edited on 27/6/08 by Dave Ashurst]
Miks15 - 27/6/08 at 10:10 PM
im onli going to blast the outside
omega0684 - 27/6/08 at 10:12 PM
i have a cabinet for sale if you want to purchase one. its pretty much brand new, with nossels and grit.
looking for £140 ono
Miks15 - 27/6/08 at 10:13 PM
thanks omega but i aslredy have a small sand blaster ill use
Dave Ashurst - 27/6/08 at 10:16 PM
Go for it..
Dave Ashurst - 27/6/08 at 10:18 PM
but go easy and stop if it cuts too deep!
GeorgeM - 27/6/08 at 10:21 PM
IIRC ali shoud be bead blasted, NOT
sand or grit. The ali will disappear
GeorgeM
liam.mccaffrey - 28/6/08 at 12:25 AM
You "should" bead blast
but ive sand blasted it and it was fine, the grit was old and i kept plenty of distance
myke pocock - 28/6/08 at 07:23 AM
I find that glass bead gives a very nice, mellow finish to alluminium and doesnt make the surface rough like alluminium oxide grits or similar.
