hi ,im wanting to remove bottom pully from xe engine .
book says torx female head!
what i have got are like multi splined female head??
is there such a bolt and what do they call it
cheers
richard
Do you want a torx socket or key?
Both are available in lots of different sizes.
Examples:
http://www.jesstools.co.uk/14pc-Female-Torx-Socket-Set_AJHR1.aspx
http://www.toolspot.co.uk/product/10pc-3-8indr-torx-bit-sockets-on-rail-double-blister
it would be the key neede but they are not torx they look to have loads of small grooves rather than a star shape?
The Socket is called an E20 socket and that nut is STUOOOPIDLY Tight!
if its standard, and similar to my later xev engine, it is a femal torx socket that you need.
[Edited on 31/8/08 by blakep82]
Torx --- the manual should give you the size, the correct size will be a really snug fit.
http://www.machinemart.co.uk/shop/product/details/cht144-40-pce-torxspline-bit-holder-s
[Edited on 31/8/08 by britishtrident]
there not torx ,
those xzn onlink look more like it
cheers
richard
This is what ur after.
http://www.machinemart.co.uk/shop/product/details/pro44-14-pce-tx-bit-set/path/socket-sets-sockets-tool-sets
On a seperate note, I've been using a set of these for almost 5 years now and haven't broken one yet. (Mechanic by trade).
Originally posted by bracey
there not torx ,
cheers
richard
the 6 small bolts are number 8 multisplines IIRC, the centre bolt is an e20 torx.
do the items in the middle of the box look like what you need
they do ,ill be getting some of them
Ribe sockets?
