Ithink i got a virus on the pc on wednesday but managed to get rid of it? Only problem have is i cant get my igoogle page up. When doing a diagnostic
check with IE8 it tells me my HTTP and HTTPS settings are ok but my firewall could be preventing connection on the FTP ports. Can anyone translate
this into english please.
after a while i get this on the screen
Warning: require_once(/usr/www/pdm/pdm-clone/podmena-host/inc/UserRequest.php) [function.require-once]: failed to open stream: Too many open files in
system in /usr/www/pdm/pdm-clone/podmena-host/index.php on line 7
Fatal error: require_once() [function.require]: Failed opening required '/usr/www/pdm/pdm-clone/podmena-host/inc/UserRequest.php'
(include_path='.:/usr/local/share/pear'
[Edited on 31/7/2009 by dave1888]
Well pomena is a Trojan virus so I think you have some more cleaning to try malwarebytes prof if you can get on the net
Some of these "Malware" things trash the Hosts file and it is used to re-driect the browser.
IF it is a windows PC have a look at the Hosts File (open it with notepad) located in c:windowssystem32driversetc
it should look like this.
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
