Vector Images
greggors84 - 15/5/06 at 04:00 PM
Need to create a vector image for printing. I want to get some t-shirts and other stuff done on www.spreadshirt.net and to print on anything but white and grey, you need to upload a vector image.
I have created a logo and converted the text to curves, do i need to convert all the image so it is just outlines? Could i do this by just drawing around all the shapes and filling them in white, or is there a special way to do it to convert them to vectors?
Alot of the image is solid thick lines and shapes, will these print ok?
Anyone know about vector images?
Peteff - 15/5/06 at 04:27 PM
What have you drawn it in. Corel and similar are vector drawing packages, your drawing is built up in layers not all on a single plane.
stevebubs - 15/5/06 at 06:40 PM
If they are bitmaps (.jpg, .bmp etc) How high a resolution are they? Quite often a decent quality embedded bitmap will print OK...
greggors84 - 15/5/06 at 10:47 PM
Ive used Photoshop, i have image ready as it comes with PS, apart from that no other imaging software. Im getting a copy of Adobe Illustrator as we speak as i was told i could use that.
Being in photoshop its made up of different layers, its a high res PSD file at the moment.
Mezzz - 15/5/06 at 10:49 PM
You can e mail them to me, I have a program that will do it for you.
joshua@iqsltd.com
greggors84 - 15/5/06 at 11:32 PM
Mezz you should have mail, let me know if it doesnt come through.
