Which one?
Mark Allanson - 22/9/07 at 05:07 PM
I am just about to do the upgrade on my computer, from 1800 athlon with 133fsb to 4200 dual core with 500?fsb.
When I bought the processor, I didn't realise that the cooler came with it so I bought one specially.
Shall I use the tried and tested AMD cooler or the much bigger 'Samurai' one? Rescued attachment Coolers.jpg
nick205 - 22/9/07 at 05:51 PM
The bigger one loos like it's a liqud cooled jobbie - do you need to plumb it in?
Either way I'd use the Samurai one as it has a cool name
cloudy - 22/9/07 at 05:52 PM
use the quieter of the two, the stock heatsink does a great job...
ecosse - 22/9/07 at 06:32 PM
Stock heatsink will do a good job, Samurai is for the clockers really
Alex
UncleFista - 22/9/07 at 08:07 PM
If it was me, I'd run the bigger one at 7volts, for good cooling with less noise.
Just use the 12v line as positive and the 5v line as the negative. I do this with all my case fans
The "pipes" in the bigger cooler are "heat pipes" there's a liquid/gas inside that evaporates and condenses transferring heat to the fins.
[Edited on 22/9/07 by UncleFista]
bimbleuk - 23/9/07 at 06:00 AM
As above ^^^^
Go for the biggest fan you can fit and run it slowly to reduce noise. The stock coolers are good at stock speeds and even a little higher but they build them to a cost so the fans are usually small and noisy. Your case cooling with have a big effect though.
RazMan - 23/9/07 at 07:19 AM
Check the AMD fan to see if it has an on-board heat sensor/speed control. If both connectors are identical, the heatpipe cooler will probably be quieter anyway as it has a larger fan, especially if it is heat controlled by the motherboard.
[Edited on 23-9-07 by RazMan]
Mark Allanson - 23/9/07 at 04:33 PM
I used the AMD one in the end as the size of the samurai was a bit of a problem.
One big problem I encountered was the MB has a power connector with 24 pins and my power supply has a 20 pin, bugger!
Ebuyer have converters for only £2 so not a disaster, but it does mean I cannot fire up the computer until Tuesday night - and there was me getting all excited
